Announcements
UV Scale Change Script?
U539446
U539446
Hello all. I have a very very large scene with thousands of different Geo sets. recently our intern UV'd all the GEO however they did not set the scale and map size to our specifications.
Is there a way to set an entire scene of objects to a Specific uv scale and map size?
Fovvl
You need no script. In the UV toolkit under transformations there is texel density. You get the size from piece you want the rest it to be, then select the rest and click set. All UVs should be now the same proportions.
U539446
Like I said, my scene is massive. When I try to select all geo and hit "set" it brings Maya to it's knees and it doesn't work on any of the sub objects either.
