Hello again,
I'm having trouble with the UV Editor and I'm on the brink of reinstalling the software but before that I would like to know if there's a solution.
My UV Editor Scale Tool is snapping. I mean, trying to scale it will only increment in a determined value and not fluidly like it's supposed to, if I press J however, it will "unsnap" and work properly but the "wrong way" will still be the default. And if I try to scale it back it will scale the UV back to 0. The other tools like rotate and move are working properly.
I have tried to reset the transformation tools in Modify > Transformation Tools but to no avail, but I'm not even sure if that would make any difference because the tools in the ViewPort are working great. This is not a problem with the scene I'm working on, if I start a new scene the problem will be there so I changed the default values somehow.
Thanks in advance.
