Announcements
Unmerges edges when moving.
k.moonsXH6PH
k.moonsXH6PH
I made a model but after rigging it, it "opens up" when I move the upper joint. I still think that this is for the modelling forum but maybe I'm wrong. I merged the edges a few times but I don't know what to do anymore.
https://imgur.com/a/AZYNQIh
https://imgur.com/a/eM3yzYE
https://imgur.com/a/X4cHRza
mspeer
Hi!
You have history(edited the object) after skinning.
You need to delete this part of the history and you may need to re-skin.
_sebastian_f
you did a lot of modeling operations after you bind the geometry to the skeleton. that should be avoided as much as possible. in your case edit > delete by type > non deformer history should work.
if not: unbind the geo. make sure your mesh is finished and delete history before skinning it again.
