Unable to Select Geometry
Hi!
I'm finding it difficult to select the extracted geometry in the attached img. I've tried the solutions to similar problems, yet nothing. I've tried checking all my layers still nthg. Also tried Display>Object Display>Untemplate. Didn't work. Please I'd appreciate any ideas
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Are you seeing that object listed in your Outliner? Is it possible to be selected from that menu?
If you are still having issues, please upload the scene file in a .zip folder, or share it in a pm 🙂 I would be happy to investigate further.
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
I sent a message, but I wanted to follow up on the thread too in case others ran into this same issue, and we can mark this as solved 🙂 I found that a piece of your geometry was in template mode:
PolySurface73 appears orange in the outliner which told me that it was in template mode, making it not selectable. To change that, select Polysurface73 in the Outliner, then select Display > Object Display > untemplate.
Jordan Giboney
Thanks for the assistance
adribnokhod
Thank you , it helped me 🙂
