Thanks for your reply.
I already cleaned up everything. I downloaded two more simple free models and it has the same problem. It seems that whatever I download is unable to be exported as .dae. If I export the models as FBX they work..
While reading or writing a file the following notifications have been raised.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'gear_1FBXASC046001' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform1' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'wheelFBXASC046001' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform2' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'antenna' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform3' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'fuselage' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform4' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'gear_1' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform5' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'box_2' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform6' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'hydraolic' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform7' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'wheel' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform8' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'box_1' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform9' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'aileron' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform10' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'engine' will be saved.
Warning: 'Null' type not supported by COLLADA. Only the transform data of node: 'transform11' will be saved.
This is what I get.
