Transfer attributes doesn't transfer UVs properly
rallewski
rallewski
Hello everyone! I can't transform uvs properly from one object to another. Objects are identical. No extra uv sets, no history. What could be the problem?
hamsterHamster
I am guessing, that transfer was based on component ID, as here it looks like the yellow edges are not connected for the second window.
I don't know the reason why thats happening in your scene, I'd probably try Topology option, instead of Component. Or even better - copy the original mesh and forget about uv transfer.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
rallewski
Thank you a lot! I tried topology mode and it worked out!
SophieStudent
Thank you 🙂
