Tool pop-up option box issue
mmitchell2u
mmitchell2u
Hey, I'm running into an issue where everytime I try to use a tool that creates a pop-up menu, I can adjust the first option, but not any of the others. For example, with the extrude tool, I can adjust the thickness with no problem, but if I try to adjust offset or change keep faces together, nothing is happening when I click or try to drag. If I have the manipulator planes visible, it tries to select those and move the faces along whichever plane it selects. Thanks for any help you guys can provide!
mmitchell2u
So after some searching, I've figured out it's something to do with the Mtoa plugin. If I move the option box around and find the perfect spot, I can adjust the other options, but if anyone else has any other ideas to fix this, it'd be greatly appreciated!
brentmc
This sounds like it could be a graphics card issue so you might want to check that you are using the certified driver for your version of Maya.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/simplecontent/content/maya-certified-...
If you are on Windows you could also try changing Preferences > Display > Viewport 2.0 to DirectX 11 as that mode tends to work better on some lower-end integrated graphics cards like Intel.
Brent McPherson
Principle Engineer
