Surface Array/Instances along Surface?
I would like to place instances of an object onto a surface, following its normals. Is there a way to instance objects along a surface or some sort of surface array functionality? I have been searching the web but could only find a script instancing along curves.
Would be really grateful for any recommendation or workaround.
Cheers!
pshwayka
You could use xGen with geometry archives. Attached is a quick example.
mspeer
Hi!
You can use XGen or MASH.
