Substance option missing
Hello!
I have been working on a model for a couple of days and wanted to add some Substances to it, but realized the option was missing.
I opened older scenes and had no problems finding Substance option there. Started a new scene - no problems as well.
Therefore, I have this problem with a single scene only. Could have I deleted anything or turned anything off?
Thanks.
EDIT: Maya 2015
ryan.harvey
Hi there,
Substance is a plug-in in Maya - you can check if the plug-in is loaded by going here:
Windows > Settings/Preferences > Plug-in Manager > and search the entire window for "Substance" and make sure it is loaded. Once it's loaded you should be able to create substance nodes via Hypershade, for example.
Hope it helps,
Ryan
Bifrost QA at Autodesk
gpmail1
I show Substance.mill in my plugins.  it is activated yet there are no substance nodes in my hypershade.
flafon20
Community Visitor
Community Visitor
I am having this same problem, did you ever get to solve it?
Hi everyone. I have problem with substance plugin too. I can not see plugin in maya plugin manager either. Could you help me?
ramazangolbas0
Observer
Observer
Just download plug-in firstly and restart Maya. Search again.
https://substance3d.adobe.com/plugins/substance-in-maya/
