Snapping to points while editing object's pivot is crashing Maya 2022
rafaelsegnini
Message 1 of 1
rafaelsegnini
Hello!
One more bug here:
Sometimes, depending on the scene, if you edit your object's pivot (pressing D) while using "snap to points", Maya 2022 will crash or freeze. This is happening with me all the time.
Now, I'm providing a sample scene, with some instructions to reproduce the error:
1- Import the provided .FBX file into a new scene. It's a simple T-Pose skeleton from Mixamo;
2- Put the skeleton into a new group (select the Hips joint and press "Ctrl+G");
3- Press "D" key to enable pivot editing, and hold "V" key while moving the pivot towards the hips joint.
Maya will crash or freeze without warning, not even trying to save a backup scene.
Tested this workflow on Maya 2020 and no issues were observed.
Hope it helps to solve one more bug 😉
Regards!
Replies (0)
