Scaling
Scaling
Cobra_2o1o
Scaling
Cobra_2o1o
Hello fellas,
How can I scale the following faces ( I want to move them away from each other ) and keep the same size of the face?
Good Evening,
I would simply delete 3 of those 4 "sections". Scale it like you wish and then mirror it twice. It is not the best way but the only way I know 😉
Life
Circlelizer a circle tool for Maya.
mspeer
Hi!
You can't use scale without scaling the size of the faces.
But you can use the Transform Tool with Symmetry "on" to move 2 faces at the same time, or you can use Edit Mesh -> Transform to manual assign the exact same transform values (if needed) to all faces and this will also be added to the history and can be animated and changed at a later time.
