Announcements
Scaling problem
Scaling problem
Message 1 of 11
Scaling problem
Hi peeps, im working on this file and anytime i scale an object i get the following message:
scale -ws -r 1 0.893969 1 ;
// Warning: Non object-space scale baked onto components. // :mad:
What does this mean, really need help on this one
Replies (10)
Message 2 of 11
n8skow
Double-click the move tool to open the options, then click the 'reset' button.
Message 3 of 11
MrMeireles
You mean RESET the Scale Tool...
Remember to share your knowledge. That's good for everyone!
MrMeireles
[Maya 2022.5/2025]
[Windows 10 Pro 64 bit Intel i9 9900K 64GB]
[MSI Suprim RTX 4080]
Message 4 of 11
Nice, thank you.  I'm well aware that its barely past 6 years but this is exactly what I needed.
Message 5 of 11
No worries, we still consult 2000 thousand years old book for today's problems Man Tongue this helped a lot!
Message 6 of 11
amaterasu-qbb
This not working with me in maya2019.
What I did is
Moved the manipulator to the bottom of the object in D.
The object was grid-snapped. (To allow the object to scale like 3dsmax.)
When I scale here, I get the error I mentioned earlier.
Just to be sure, pressing D and right-clicking in the orient mode of the manipulator, right-clicking on the Marking-menu, and selecting Reset Pivot and snapping the manipulator to the bottom of the object again did not change the situation.
The overall scale is fine, but it sucks.
the scale option
Message 7 of 11
faisal.pvz95
In the modelling toolkit, go to scale settings and choose object. I had it on world and i changed it to object and the warning disappeared.
Message 8 of 11
Milosava
This worked! Thank you!
Message 9 of 11
sebago96
Thank you so much for sharing this
Message 10 of 11
brunogf13
That did it for me too! Cheers!
Message 11 of 11
jjbbqq
This warning happens when you scale the object in object mode, but didn't use the object space for axis orientation (Scale Tool Settings > Axis Orientation set to Object). By default, Scale Tool use object space as pivot orientation, and any scaling you made is stored in object's transform node Scale.XYZ attribute and this attribute only uses object (local) space. When you set Axis Orientation other than Object, Maya has to save the scaling as tweaks directly into the shape node. You can see those tweaks in Channel Box's CVs (click to show) when you select the vertex. This is called "baked onto".
