Announcements
Problem with extruding faces
I am a newbie to Maya and I am following a tutorial that calls for me to extrude certain faces on a polygon sphere. I right click the sphere, select faces from the menu, clicked on Edit Mesh-Extrude and it extrudes the vertices. No matter what I do I can't get it to extrude the faces. I know I am missing something, just can't figure out what it is.
Thank you
mspeer
Hi!
Please add screenshot(s) or a screencast.
I posted a video of the steps I took, but the screencast did not record me right click choosing Face and Extrude, but the end result you can see.
_sebastian_f
make sure you are in the right section of the edit mesh menu.
without seeing what you are actually clicking on it´s just a guess and i don´t have 2015 installed (any reasons for not using a more current version?) but if i remember there was a time when there were multiple extrudes. the menu is separated in components / vertex /edge etc. make sure to use the face extrude (in more current versions that´s unified into just 1 extrude command for components).
