Problem baking normal map in Substance
philipe_cabral
philipe_cabral
Community Visitor
Community Visitor
Hi everyone
I'm trying to bake a normal map in Substance Painter and around the edges look bad, but when I export the same model and bake inside Marmoset Toolbag it looks okay.
Before exporting the fbx from Maya, I had applied soften edges, freezed transformation, reset transformation and delete history. I also tried using mesh display - soften/harder edges - Textures borders.
artfully3d
Are you baking the mesh to itself or baking a low/high version?
In substance, those bad edges are generally caused by frontal and rear distance settings, or discrepancies between a high mesh and a low mesh. The trial and error process would be to bake your normal map using different frontal/rear distances until you have minimized or fully removed the problem areas.
Christoph_Schaedl
For me this looks more like a modeling issue. Make this overlaps more pyramid shaped. From a really low lowres you cant bake that shape. You need more geo.
Maybe with a bigger cage.
https://linktr.ee/cg_oglu
