Announcements
Please help, i get this ACCESS_VIOLATION error
Message 1 of 1
hello, this the the error log
please help, I need to fix it 😞 I'm still learning the program.
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x00000008
Fault address: 35DD4246 in E:\Autodesk\Maya2019\bin\OpenMaya.dll
0001:001F3246 Logical offset (see .map file for location)
Call stack:
Module: E:\Autodesk\Maya2019\plug-ins\MASH\plug-ins\MASH.mll (-exported-)
Decl: ??
Decl: ??
Decl: ??
Module: E:\Autodesk\Maya2019\bin\OpenMaya.dll (-exported-)
Location: OpenMaya.dllTHdependNode::computePlug + 6B bytes
Decl: public: virtual void __cdecl THdependNode::computePlug(class Tplug const & __ptr64,class TdataBlock & __ptr64) __ptr64
Module: E:\Autodesk\Maya2019\bin\DependEngine.dll (-exported-)
Location: DependEngine.dllTdependNode::dbEvaluate + 4FF bytes
Decl: protected: virtual bool __cdecl TdependNode::dbEvaluate(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTdependNode::stackSafeDbEvaluate + BE bytes
Decl: protected: bool __cdecl TdependNode::stackSafeDbEvaluate(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTdependNode::mpSafeDbEvaluate + 34 bytes
Decl: protected: bool __cdecl TdependNode::mpSafeDbEvaluate(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTdependNode::processEval + 1BE bytes
Decl: protected: virtual bool __cdecl TdependNode::processEval(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTfastTrack::debugMe + 82B bytes
Decl: public: static void __cdecl TfastTrack::debugMe(class TfastTrack const & __ptr64,unsigned int)
Location: DependEngine.dllTplug::evalConnectionValue + DD bytes
Decl: public: bool __cdecl Tplug::evalConnectionValue(bool,class TdgContext const & __ptr64,class TdataHandle & __ptr64)const __ptr64
Location: DependEngine.dllTplug::evaluateValue + 101 bytes
Decl: public: bool __cdecl Tplug::evaluateValue(class TdataHandle & __ptr64,class TdataBlock const & __ptr64,bool)const __ptr64
Location: DependEngine.dllTdataBlockDG::evaluateValue + 3E bytes
Decl: private: void __cdecl TdataBlockDG::evaluateValue(class Tplug const & __ptr64,class TdataHandle & __ptr64) __ptr64
Location: DependEngine.dllTdataBlockDG::value + 18E bytes
Decl: public: virtual class TdataHandle __cdecl TdataBlockDG::value(class Tattribute const & __ptr64) __ptr64
Location: OpenMaya.dllAutodesk::Maya::OpenMaya20190000::MDataBlock::inputValue + 54 bytes
Decl: public: class Autodesk::Maya::OpenMaya20190000::MDataHandle __cdecl Autodesk::Maya::OpenMaya20190000::MDataBlock::inputValue(class Autodesk::Maya::OpenMaya20190000::MObject const & __ptr64,class Autodesk::Maya::OpenMaya20190000::MStatus * __ptr64) __ptr
Decl: ??
Location: DependEngine.dllTevaluationNode::evaluateDirtyPlugs + 455 bytes
Decl: private: bool __cdecl TevaluationNode::evaluateDirtyPlugs(class TdataBlockDG * __ptr64,enum TevaluationNode::TdirtyPlugType) __ptr64
Location: DependEngine.dllTevaluationNode::taskEvaluation + 234 bytes
Decl: public: void __cdecl TevaluationNode::taskEvaluation(class TsyncMessage const & __ptr64) __ptr64
Location: DependEngine.dllTparallelExecution::evaluateAndVisitChildren + BF bytes
Decl: private: class TparallelExecution::TexecutionNodeHandle __cdecl TparallelExecution::evaluateAndVisitChildren(class TevaluationNode * __ptr64) __ptr64
Location: DependEngine.dllTparallelExecution::evaluateAndSchedule + 52F bytes
Decl: private: bool __cdecl TparallelExecution::evaluateAndSchedule(void) __ptr64
Location: DependEngine.dllTparallelExecution::sAddNodesWithinDepthToSet + BE2 bytes
Decl: protected: static void __cdecl TparallelExecution::sAddNodesWithinDepthToSet(class TgraphVisit<struct TexecutionNode> const & __ptr64,struct TexecutionNode * __ptr64,struct TexecutionNode * __ptr64,enum TgraphVisitInfo::eVisitOrder,enum TgraphNodeLayer)
Module: E:\Autodesk\Maya2019\bin\tbb.dll (-exported-)
Location: tbb.dlltbb::interface7::internal::task_arena_base::internal_execute + 138 bytes
Decl: protected: void __cdecl tbb::interface7::internal::task_arena_base::internal_execute(class tbb::interface7::internal::delegate_base & __ptr64)const __ptr64
Location: DependEngine.dllTparallelExecution::evaluateImplementation + 9A bytes
Decl: public: virtual bool __cdecl TparallelExecution::evaluateImplementation(void) __ptr64
Location: DependEngine.dllTevaluationGraph::evaluate + 31B bytes
Decl: public: bool __cdecl TevaluationGraph::evaluate(bool) __ptr64
Location: DependEngine.dllTevaluationManager::evaluate + E7 bytes
Decl: public: bool __cdecl TevaluationManager::evaluate(class TdgContext & __ptr64,bool) __ptr64
Location: DependEngine.dllTcipEvaluationManager::operator= + 23E bytes
Decl: public: class TcipEvaluationManager & __ptr64 __cdecl TcipEvaluationManager::operator=(class TcipEvaluationManager const & __ptr64) __ptr64
Location: DependEngine.dllTdependGraph::setTime + 138 bytes
Decl: public: bool __cdecl TdependGraph::setTime(class TanimTime const & __ptr64,bool) __ptr64
Module: E:\Autodesk\Maya2019\bin\Shared.dll (-exported-)
Location: Shared.dllTfrozenEvaluator::sProcessDownstream + 2261 bytes
Decl: protected: static void __cdecl TfrozenEvaluator::sProcessDownstream(class TgraphVisit<class TevaluationNode> const & __ptr64,class TevaluationNode * __ptr64,class TevaluationNode * __ptr64,enum TgraphVisitInfo::eVisitOrder,enum TgraphNodeLayer)
Module: E:\Autodesk\Maya2019\bin\ExtensionLayer.dll (-exported-)
Location: ExtensionLayer.dllTidleAction::preDoIdleAction + F bytes
Decl: private: void __cdecl TidleAction::preDoIdleAction(class Tevent const & __ptr64) __ptr64
Location: ExtensionLayer.dllTarrayTdeviceHandlerPtr::size + C3 bytes
Decl: public: unsigned __int64 __cdecl TarrayTdeviceHandlerPtr::size(void)const __ptr64
Location: ExtensionLayer.dllTperiodElapsedMsg::operator= + 19F bytes
Decl: public: class TperiodElapsedMsg & __ptr64 __cdecl TperiodElapsedMsg::operator=(class TperiodElapsedMsg const & __ptr64) __ptr64
Location: ExtensionLayer.dllTeventHandler::doIdles + 27D bytes
Decl: public: static bool __cdecl TeventHandler::doIdles(void)
Location: ExtensionLayer.dllTidleLicenseAction::doIdleAction + 686 bytes
Decl: protected: virtual void __cdecl TidleLicenseAction::doIdleAction(class Tevent const & __ptr64) __ptr64
Module: E:\Autodesk\Maya2019\bin\Qt5Core.dll (-exported-)
Decl: public: virtual bool __cdecl QObject::event(class QEvent * __ptr64) __ptr64
Module: E:\Autodesk\Maya2019\bin\Qt5Widgets.dll (-exported-)
Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 112 bytes
Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplication::notify + 1B27 bytes
Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: ExtensionLayer.dllTwindowManager::windowPreferencesAreEnabled + 3CD bytes
Decl: public: bool __cdecl TwindowManager::windowPreferencesAreEnabled(void)const __ptr64
Location: Qt5Core.dllQCoreApplication::notifyInternal2 + B9 bytes
Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
Location: Qt5Core.dllQEventDispatcherWin32::event + E5 bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::event(class QEvent * __ptr64) __ptr64
Location: Qt5Core.dllQCoreApplicationPrivate::sendPostedEvents + 22A bytes
Decl: public: static void __cdecl QCoreApplicationPrivate::sendPostedEvents(class QObject * __ptr64,int,class QThreadData * __ptr64)
Module: E:\Autodesk\Maya2019\plugins\platforms\qwindows.dll (-exported-)
Location: qwindows.dllqt_plugin_query_metadata + 24DF bytes
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + DA8 bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Module: C:\WINDOWS\System32\USER32.dll (-exported-)
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 4D6 bytes
Location: qwindows.dllqt_plugin_query_metadata + 24B9 bytes
Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Location: Qt5Core.dllQCoreApplication::exec + 147 bytes
Decl: public: static int __cdecl QCoreApplication::exec(void)
Location: ExtensionLayer.dllTapplication::start + CE bytes
Decl: public: void __cdecl Tapplication::start(void) __ptr64
Module: E:\Autodesk\Maya2019\bin\maya.exe (-exported-)
Decl: ??
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + F504 bytes
Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + E47F bytes
Module: C:\WINDOWS\System32\KERNEL32.DLL (-exported-)
Module: C:\WINDOWS\SYSTEM32\ntdll.dll (-exported-)
End of stack
//crash log file name = C:\Users\admin\AppData\Local\Temp\MayaCrashLog201130.0942.log
//version = 19.0.7966.0
//cut = Tue 12/11/2018, 201812112220
//current scene = unDisclosed
//command history (most recent last):
//last tool: renderWindowSelectContextItem
//panel with focus: modelPanel4
//visible panels:
// modelPanel4 outlinerPanel1
//Memory usage:
// 9932.633 Mb Free Memory
// 18517.434 Mb Free Swap
// 737.742 Mb Current
Replies (0)
