Phantom nCloth history persists. Help please.
lightstream
Message 1 of 14
lightstream
Maya 2019. After weeks of sculpting and modeling, my bedding is complete. I have deleted all nCloth history, all document history, removed all nCloth nodes and colliders from the Outliner. There does not appear to be anything remaining to delete! But when I export this model as an FBX and re-import it into Maya, everything has gone back to it's pre-nCloth state. [See pics.] I have a client who needs this model as an FBX. I could really use some advice. Thanks.
Replies (13)
Message 2 of 14
hamsterHamster
Still, can you Export Selection with needed objects only to a new scene? Also, what do you see in the Node Editor for those selected objects, pick one, click on Input And Output Connections button.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Message 3 of 14
mspeer
Hi!
There is a very simple solution.
Just use Edit -> Duplicate, this creates a copy based on the current state, without any history.
Message 4 of 14
lightstream
here. is an example from the node editor
Message 5 of 14
lightstream
Thanks for the suggestion. I thought this would be the perfect example of an obvious solution, but alas the duplicated items still carried the nodes the reply to hamster. So, when I exported them, the nCloth memory was still there. All I get is flat polys.
Then I tried deleting the shape nodes from the node editor [see pics], and that didn't help either.
I gotta think this history has to be somewhere so that I can delete it.
Message 6 of 14
hamsterHamster
You can export your models as OBJ files, which for sure will leave nothing besides meshes. Then import back into new scene, check smoothing and reapply shaders, export FBX.
,,,_°(O__O)°_,,,
Message 7 of 14
mspeer
Hi!
Please try the following.
1. Edit -> Duplicate
2. Edit -> Delete All by Type -> History
3. File -> Optimize Scene Size
Here this works.
For further help, please provide a scene-file.
Message 8 of 14
lightstream
I will try the OBJ work-around, but I would like to know why this is happening. Attaching the file:
Message 9 of 14
hamsterHamster
Opens fine here. However, you have many extra shapes (intermediate objects) there, that are some leftovers from simulation/deformation. In the image you can see the green objects - those are the unhidden ones just for the comforter. I believe it is safe to delete them, just it will take some manual iteration through all ex-nCloth objects. I suspect those might be the cause of strange exports.
EDIT: Yes, basically, you select the BEDDING group and export selected as OBJ, it gets stripped of those intermediate shapes, just need to reassign the materials and soften the edges.
,,,_°(O__O)°_,,,
Message 10 of 14
lightstream
I'm confused since when I open the .mb file, the green thing is not there and does not show up in the outliner. Is your preview from the .fbx or the .mb?
Message 11 of 14
hamsterHamster
From .mb
Open the AttrEd for the conforter - you will see many output mesh nodes, where in Object Display section you will see the Intermediate Object flag.
Export as .obj the entire group - just tested, this is quickest way to get rid of those.
,,,_°(O__O)°_,,,
Message 12 of 14
mspeer
Hi!
This is not the original scene with the nCloth files, because of this my steps will not work here.
The cause for the other shapes is based on how deformers work, you have one reference shape and one output shape and both are parented to the same transform node.
In the current provided scene simply delete all mesh/shape nodes that are not connected to a shader.
I am not sure why the FBX export prefers the hidden original shape, but for me this looks like a bug.
As suggested by @hamsterHamster  try an other export format like OBJ which takes the visible shape.
Please report this problem (bug?) to Autodesk.
In Maya main menu:
Help -> Speak Back -> Report a Problem
Message 13 of 14
lightstream
That was it. Thanks. Will also report the bug.
Message 14 of 14
jen_steinkamp
Select File->Optimize Scene Size->options
     Select Remove: Unknown nodes
Or if that did not work when you export files, try this:
Select one shape at a time
Select Windows->General Editors->Hypergraph: Connections
     Select the light grey node
     Hit delete
     Close the Connection window
Repeat for each shape
