Announcements
Open CL error at MAYA update 4
When i try to use the 3 buttom to smooth a object, the object crashes and appears this messege.
Im just updated maya 2017 update 3 to update 4.
mspeer
Hi!
There seems to be missing a proper 3D Graphic Card or/and driver.
Only the Intel onboard graphic seems to be used, although some NVIDIA Drivers are found?
1. Make sure the correct Graphic Card is used
2. Update Drivers.
3. Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
4. Disable OpenCL
"To disable acceleration, use the environment variable MAYA_OPENCL_IGNORE_DRIVER_VERSION = 1".
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Mod...
Thanks for your suggestion 🙇
