Announcements
Noob question...
Noob question...
Noob question...
I have an obj file and I would like to seperate it into induvidual parts.
I edit the model in UVSHELL mode and I can select the induvidual parts, but when I try "export selected" it does not export anything but a blank file.
Also it has a default UV layout but I want to create a new one. How do I delete the default UV's?
I have attached a screenshot as well as the Maya File.
Thanks for any help.
damaggio
Select the faces you want to separate..example the shirt ..then Edit Mesh>Extract
About the current UV you can just create a new one it will override make sure there's only one UV map UV Editor>UV Sets map 1.
damaggio
I just looked at the UVs , is well made and organized, I would not touch that, if you dont have the textures it would be just easy to take into photoshop and create a new one....doing a new UV as good as this one will take some time.
I'd go with what damaggio said and try selecting the faces and Edit Mesh>Extract. You can also try Mesh>Separate, which will separate all the different pieces of the model into different polymeshes.
