Announcements
move scale rotate issues
I seem to constantly having to select the move tool twice or reselect the object to move. Im used to working fast and it slows my work flow so much I find I keep trying to select an objects verts, faces or edges and getting this marker menu show up instead of the selection moving, its irritating as hell and there must be a way to turn it off
damaggio
HI omiles , I have the same problem, this is apparently a bug that hasn't been fixed by Autodesk , you can try to reset your preferences but I doubt that the problem will disappear.
yea I tried putting all the settings back to default and it still occurs. Was fine on previous versions these later ones are really awful to work with.
damaggio
you may have noticed this already but once the hotbox appears just press the tool shortcut w, E or R and the tool will work again until the glitch reappears.
Yea thanks, someone at the office mentioned that though when you want to
quickly move rotate scale something having to press twice really slows you
down specially as you'll inevitably press once and end up dragging and
getting some annoying marker menu that will switch your section settings
etc... should just be fixed.
damaggio
Hey omiles, could you please describe the basics of your machine and the OS,Maya version,  I'would like to pass  this on  to someone at Autodesk.
Thanks.
