Announcements
Maya 2017 File scripts error
Good morning,
two days ago Maya 2017 started to show up this error:
Error file :C/Program Files?Autodesk/Maya 2017/scripts/others/drl nit.mel line 1961
I'd like to know if anyone has figured out the solution.
This problem hasn't apparently affected any works but it appears everytime I open Maya and I select an object both in a new scene and in one of my works.
Thanks!!
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Thank you very much!
I solved the problem following your instructions.
Sara
Sara
