make image planes all the same size
Guys how can I edit the image planes to be the same size all of them
the problem is when I modify my object based on the side view, it doesn't fit the bottom view and neither the front view
and when I modify my object based on the front view, the object doesn't fit the side view, so I'm kind of stuck
here is a screen shot shows what do I mean
pshwayka
Select each image plane and adjust width and height under the "Placement Extras" section in the attribute editor.
yes, that helps so much, but I meant that what is the the best sizes for front size, side size and top size to be all the proportional
I want them to be proportional
pshwayka
One technique is to create a cube and scale it so that it matches a particular featue in one of the images (for example, the wingspan) and then scale the other images to line up with that cube.
