Announcements
Low Poly model freezes Maya when selected
wreliford
wreliford
Will someone take a look at this file and tell me what is wrong with it. First of all it is a small file file 42k but it takes 15 seconds to open in Maya. Take in consideration that I have a different file that  is 2.22 Gigs and it only take 8 seconds to open. This 42k file, whenever I select anything, Maya freezes for up to a minute before I can do anything. This object has less than 75k faces. Going back to the 2.22 gig file, which has over 6.45 million faces I can select and interact with now issues. There is something in the 42k file that is cause Maya to choke. I have shared a link from my dropbox of the file for your review.
https://www.dropbox.com/s/pollngfybpcfnn0/industrial03.ma?dl=0
My drivers are updated to the latest nVidia 436.30
cpu i9 9980xe 4.6 OC
gpu 2080 ti  (4)
Windows 10 pro
ram 128 gigs
Maya 2019.2
mspeer
Hi!
This i not one low poly model,
the scene consists of more than 18000 low poly models,
that's a huge difference and pretty sure the reason for your problems with this scene.
wreliford
Where do you see that number? I see 86192 faces.
mspeer
Hi!
I used a custom script, but just check the Outliner, there are thousands of objects.
_sebastian_f
also to see the amount of selected objects you can use : display > heads up display and enable object details.
