Just learn maya. Selecting
Hi
When i use "selective rectangle" then all polygons are selected - all polygons means front and polygons that are allocated on opposite side of the mesh - object
How select only front polygons?
fowlert
In the Tool Settings window, when you are in Select/Move/Rotate/Scale tools, you want to turn on "Camera-based Selection".
The other place people access this is through the Ctrl-Shift RMB marking menu.  Do Ctrl-Shift-RMB while in one of those tools and go South into the "Select" sub-menu and you'll find a toggle in there as well.
Thank you - it was that what i needed
But for now - i need to find out how to swith to this and to opposite mode pressing a key
