Announcements
Is there a way to extrude an object from it's negative side?
bobopet
bobopet
I'm trying to do an extrusion and this is what I get. The most painful thing to me in maya is extruding. Is there a way to do this and end up as if you'd do a normal extrusion?
Video: https://gyazo.com/0eb039784385b2f80ea273ca2ef70c7a
begerdesign
What you do in the video is not an extrusion, but a scaling.
damaggio
Your object has no thickness that's why , you should not have made the top part of model by extruding an edge from a solid shape.
this can render fine but it will create problems later.
you can either detach the top area and extrude or select the profile edges and do Modify-Convert edge to curve and then do a clean revolve of the shape.
bobopet
It is an extrusion. I am doing shift + scale, not just scale
Either way. You cand do what he says about detaching the shape or extrude it and then select the black faces and invert the normals. They are reversed. That´s the reason why they are black.
