Image Planes Problem
Hi - I am brand new to Maya and an old blender user.
I am following a tutorial but I have having problems with "Image Planes" - orthographic references for modeling.
I'm in Maya 2016
There are two problems actually:
1. I can't select the planes through the viewport. not by clicking or dragging a box selection. I can only select through the outliner.
2. The tutorial said I should limit the visibility of the plane to only the specific view of it. Only - I can't do. Whenever I try to change "side" to "front" it snapped back to "side" and won't let me do it.
[img]http://i.imgur.com/hgvfJO1.png[/img]
J450NP13
Use the corresponding viewport with the same view of the image plain.
If the image plain is an image of the side of your object...use the side viewing viewport....
Sorry but It's not working. Nomatter what view I can't select those. Also - in the tutorial it worked FINE. In any view.
J450NP13
Explain the steps you are using to add an image plain to a viewport
pshwayka
Did the tutorial tell you to create the image plane on its own display layer? If so, make sure the "R" flag is not on. If it is, that will prevent you from selecting the image plane in the viewports.
