Announcements
How To Change Multiple Offset-Edge-Loop Parameters
Jrtrudeau
Jrtrudeau
Hello All,
I'm wondering if there's a way to change multiple parameters of the same action in Maya. More specifically, I have a bunch of Offset-Edge-Loops in my history input, but no way to change all the offset distances to the same number. I thought that you could do this in the Attribute Spreadsheet, but I can't seem to find anything when I use it.
Any help is very, very much appreciated.
JRT
Justin Trudeau
Set Design | Parametric Modeling | Digital Fabrication
JustinRTrudeau.com
Kahylan
Hi!
Knowing how to script can come in really handy for things like this. Here is a Python script that does what you want:
import maya.cmds as mc
def setAttributes(value = None, attr = None):
    list = mc.ls(sl = True)
    for s in list:
        mc.setAttr("{0}.{1}".format(s, attr), value)
setAttributes(value = 0.4, attr = "offset")
Select all the polyDuplicateEdge nodes you want to change, change the value in the last line to the value you need and execute the script from a Python tab.
I hope it helps!
Jrtrudeau
@Kahylan , awesome, thanks so much. I agree, I really do need to put a little more effort into learning Python or Mel. Right now, my knowledge consists of editing lines of code I copy while echo all commands enabled. I then cross my fingers and hope for the best.
Thanks again, I'm going to give that script a whirl tomorrow morning.
JRT
Justin Trudeau
JustinRTrudeau.com
