Announcements
Hi guys. I'm starting to use Maya, I need to add an object using this highlig
kookiebiscoito02
kookiebiscoito02
Please explain your problems in detail. What do you want to know?
kookiebiscoito02
I would like to know where to find this tool that is (a cilia drilled in the middle) (sorry I do not know her name - it is highlighted in red in the photo.). And how to add it in the "Poly Modeling" taskbar.
I think the red marked snapshot you are showing it is older maya version and the icons and colors have been changed a bit in newer maya version. But you can get all the menu and item under Create>Polygon Primitives menu and the red marked you are showing this is Polygon Pipe. If you want to add it in your custom shelf then first create a custom shelf and open the menu containing the item you want, then Ctrl + Shift + click the menu item and it will be added to your shelf.
