HELP! I can't see the part of texture in material
I use Maya for Unreal Engine 4. Everything would work well. But now, I made my models part to group (fbx) and I add material to my model (as I always do). I exported my model into UE4, I can't see the part of texture. This would always work well. What do you think is this Maya problem or UE4? What should I do?
Just some part of model works.
To export the scene to your Unreal project
Select File > Send to Unreal > Set Unreal Project, then browse to select a valid, local Unreal project and click Select. (You need to set the project only once. It's not necessary to set the project again for subsequent export operations.)
Select File > Send to Unreal, then select All (to export the whole scene) or Selection (to export only selected objects).
Maya exports the selected objects or the entire scene to the specified Unreal project folder, so you can immediately import the file into your Unreal level.
