Announcements
Everything is apart in smooth preview, no idea how to fix it.
Oi, First of all I've made: http://screenshot.sh/oAd0AW93bo9dO (every part was made out of different poly cubes, placed next to each other)
Everything is combined: http://screenshot.sh/owkyDFbUPsqJC
Yeah, it's very basic I know that 😛 Anyway, after pressing "3" to see things smoothed... boom: http://screenshot.sh/mFtbHhQONUuZS
I'm not sure if it's merge, combine issue or something else. Thanks in advance!
Fixed, adding aditional edge loops solved the problem, tho there's one more thing I'd like to know. I know in maya 2015 there was a menu "normals" with soften and harden edges. My question is - where is it maya 2016? Soften / harden under mesh display doesn't do anything. 😞
pshwayka
You've found it...and it does seem to work. Below is a default torus with soften edge and harden edge applied. Make sure you have smooth mesh preview turned off to view hardened edges.
Thanks sir.
I ran into another problem after adding a blanked using nCloth.
Here's screenie: http://screenshot.sh/m7tQQvc8DQdKs
It was working ok with the pillow.
