Error reading a file on a mac, the figure displays strange stretching artifacts.
Message 1 of 1
The error happens when I try to open a file on my mac, it doesn't occur on windows. The figure just displays some kind of deformations or stretching artifacts and can't really know why is it happening. I really need some help I'd appreciate whatever you can help me with. Here is attached one snapshot of the figure, and also it's pasted the code that apparently describes the error, thank you!
file -f -new;
// untitled //
commandPort -securityWarning -name commandportDefault;
doOpenFile ("/Users/vivianmelo/Downloads/troll_peque_ultimo.mb");
// File read in 0.014 seconds.
// Warning: file: /Applications/Autodesk/maya2015/Maya.app/Contents/scripts/others/pv_performAction.mel line 780: /Users/vivianmelo/Downloads/troll_peque_ultimo.mb has no references. Bypassing Preload Reference Editor. //
file -f -options "v=0;" -esn false -ignoreVersion -loadReferenceDepth "none" -typ "mayaBinary" -o "/Users/vivianmelo/Downloads/troll_peque_ultimo.mb";addRecentFile("/Users/vivianmelo/Downloads/troll_peque_ultimo.mb", "mayaBinary");
requires -nodeType "mentalrayFramebuffer" -nodeType "mentalrayOptions" -nodeType "mentalrayGlobals" -nodeType "mentalrayItemsList" -nodeType "mia_material_x" -nodeType "mi_metallic_paint_x" -nodeType "misss_fast_lmap_maya" -nodeType "misss_fast_skin_maya" -dataType "byteArray" "Mayatomr" "2015.0 - 3.12.1.16 ";
# mental ray for Maya 2015
// Mental ray for Maya: using startup file /Applications/Autodesk/mentalrayForMaya2015//maya.rayrc.
# mental ray for Maya: setup
# mental ray for Maya: initialize
# mental ray for Maya: register extensions
// mental ray Node Factory: loaded
# mental ray for Maya: successfully registered
# mental ray for Maya: loading startup file: /Applications/Autodesk/mentalrayForMaya2015//maya.rayrc
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/abcimport.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/abcimport.dylib
// generating Maya nodes...
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/AdskShaderSDKWrappers.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/architectural.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/architectural.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/base.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/base.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/basehair.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/basehair.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/bifrostMR.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/bifrostMR.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/bifrostphenMR.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/builtin_bsdf.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/builtin_object_light.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/contour.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/contour.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/layering.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/layering.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/layering_phen.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/mrptex.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/mrptex.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/paint.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/paint.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/physics.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/physics.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/production.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/production.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/subsurface.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/subsurface.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/surfaceSampler.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/surfaceSampler.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/userdata.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/userdata.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/useribl.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/useribl.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/xgenMR.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/xgenMR.dylib
requires -nodeType "ilrOptionsNode" -nodeType "ilrUIOptionsNode" -nodeType "ilrBakeLayerManager" -nodeType "ilrBakeLayer" "Turtle" "2015.0.0";
updateRendererUI;
+++++++ Turtle for Maya registered successfully ++++++
// Error: line 0: The transform 'trollpeque_junio:huesos:nurbsCircle15' has no 'MeñiqueDerecho' attribute. //
// Error: line 0: Node "trollpeque_junio:huesos:nurbsCircle15" has no attribute "MeñiqueDerecho". //
// Error: line 0: The transform 'trollpeque_junio:huesos:nurbsCircle13' has no 'MeñiqueIzquierdo' attribute. //
// Error: line 0: Node "trollpeque_junio:huesos:nurbsCircle13" has no attribute "MeñiqueIzquierdo". //
dataStructure -fmt "raw" -as "name=externalContentTable:string=node:string=key:string=upath:uint32=upathcrc:string=rpath:string=roles";
// externalContentTable //
applyMetadata -fmt "raw" -v "channel\nname externalContentTable\nstream\nname v1.0\nindexType numeric\nstructure externalContentTable\n0\n\"trollpeque_junio:ReflectionMap\" \"fileTextureName\" \"/Applications/Autodesk/Mudbox2015/Mudbox.app/Contents/MacOS/Textures/Lightprobes/horizon.exr\" 817280373 \"\" \"sourceImages\"\n1\n\"trollpeque_junio:huesos:ReflectionMap\" \"fileTextureName\" \"/Applications/Autodesk/Mudbox2015/Mudbox.app/Contents/MacOS/Textures/Lightprobes/horizon.exr\" 817280373 \"\" \"sourceImages\"\n2\n\"jiggle1Cache\" \"hiddenCacheName\" \"hidden1_jiggle1.mcj\" 4262543975 \"\" \"\"\n3\n\"jiggle1Cache\" \"cacheName\" \"troll_peque_ultimo.mb_jiggle1.mcj\" 3753996417 \"\" \"\"\n4\n\"pantalon:ReflectionMap\" \"fileTextureName\" \"/Applications/Autodesk/Mudbox2015/Mudbox.app/Contents/MacOS/Textures/Lightprobes/horizon.exr\" 817280373 \"\" \"sourceImages\"\nendStream\nendChannel\nendAssociations\n" -scn;
// 1 //
// Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
Please check the Script Editor for details. //
// File read in 7.6 seconds.
updateRendererUI;
// AbcBullet v1.0 using Alembic 1.5.0 (built Jul 26 2013 11:01:23)
updateRenderOverride;
// cgfxShader 4.5 for Maya 2015.0 (May 19 2014)
// AbcExport v1.0 using Alembic 1.5.0 (built Jul 26 2013 11:01:23)
// AbcImport v1.0 using Alembic 1.5.0 (built Jul 26 2013 11:01:23)
updateRendererUI;
select -r joint5 ;
select -r trollpeque_junio:Gaban ;
select -r trollpeque_junio:Guante_Izq ;
select -cl ;
select -r trollpeque_junio:Guante_Izq trollpeque_junio:huesos:nurbsCircle22 ;
select -cl ;
select -r trollpeque_junio:Guante_Der trollpeque_junio:huesos:nurbsCircle22 ;
Replies (0)
