Draw polygon between vertices
unity2dtutorial
Observer Observer
unity2dtutorial
Observer
Observer
How can I select for example 20 vertices and draw a polygon for them?
Kahylan
Hi!
There are Multiple ways to do this.
The easiest is probably using the "Mesh>Fill Hole" command, but that will leave you with an N-Gon that you then have to cut up into quads.
You can also use the "Mesh Tools>Append Polygon" tool and draw multiple polygons between the edges.
Or you select edges on opposite sides and use the "Edit Mesh>Bridge" command.
Or you use a combination of those tools. For a hole with 20 vertices I would normals use 4 edges on opposite sides and use a bridge command with 3 Divisions, then bridge between the middle two edges on each side which leaves 4 holes with 4 edges on which I use the Fill hole command.
I hope this helps!
