Announcements
Cuts in doing UVs remove/delete
while UVing I'm doing the cuts in my mesh and I have cuts that I don't like ...how can I remove or delete that cuts I made?
I solved it myself when switching into edge mode, selecting and then deleting your UV cuts of choice.
Hope it works out as you wish 🙂
The correct way to remove an uv cut, is using the sew. Slelect the cut using the edge tool and then click
UV Toolkit>Cut and Sew> sew .
mihirsbcc
That is the correct answer , Sew.
