Announcements
Collapse edges command, odd behavior
abercaine
abercaine
When using the collapse command on a single row of edges it works correctly and the edge is centered.
But if try this on more than 1 row you have this shift on the right, why it behaves like that?
mspeer
Hi!
First one edge ring will be collapsed and then the second one.
Do it one after the other (two times using Collapse) and you get the same result.
abercaine
hi
are you sure?
even if i do it 2 times it wont be aligned in the center
mspeer
Hi!
Yes that's what i wanted to say.
In the background it's done 2 times, so the result is not centered.
IF you want a centered line (keep the original edge) you have to use an other approach.
