Announcements
Can't snap object to Deformermer ClusterHandle in Maya 2017
Can't snap object to Deformermer ClusterHandle in Maya 2017. Anyone can help?
In Maya 2016 it works perfect:
-Select object
-Hold V and drag towards C to snap object
mspeer
Hi!
I can snap to the ClusterHandle in Maya 2017, but it seems to have an offset.
Workaround with Constrain:
1. Select the Cluster Handle
2. Select your Object
3. in Animation menu: Constrain -> Point (default: Maintain offset should be off )
4. Delete pointConstrain Node (in Attribute Editor go to constrain tab, click on button Select and then in main menu Edit -> Delete or use the Node Editor)
Hi!
Thank you for your help, it realy works!
But still i can't snap to ClusterHandle in Maya 2017 (http://take.ms/o3pCE) using selected objet and holding V+lmb...
I opened the same scene in Maya 2016 and it works perfect... What's wrong?
mspeer
Hi!
Move the cluster handle far away and set the envelope to none, so the handle is far away from other objects in free space. Try snap again, you should  see the offset snap.
saihtam
I can snap transforms to clusters as well, and as mspeer I get an offset. Really strange. In 2017 that is.
- Mathias
