Announcements
Bubbles in the coffee
dersutton
dersutton
I would like to know how I can create bubbles in a cup of liquid?    For example,  you just poured a cup of coffee and you see bubbles around the edge hugging the cup.
If somebody can point me in the right direction on how to create this effect; I would appreciate hearing from you.
Attached is an image to illustrate what I would like to do.
Thank you.
t_chanma
Hi there,
This would best be done with a Bifrost liquid + foam simulation.  Make the mug a container and pour the bifrost "coffee" into it, then render a frame where the foam looks the way you want.
Here's the relevant section of the documentation to get you started: http://help.autodesk.com/view/MAYAUL/2018/ENU/?guid=GUID-5ADC1C22-E429-4F11-85D2-0612E6A378FD
Matt C
Senior Content Experience Designer
Maya Documentation | Maya Learning Channel |
dersutton
Hi
Sorry for the delay in replying.   Thanks for the information. I'll run through the tutorial tomorrow if possible.
Much appreciated.
Thank you.
