Boolean operations on quick select sets
Is it possible to perform boolean operations on 2 or more quick select sets?
For example: select all faces which are part of set 1 but not a part of set 2.
If it's not a part of maya, can it be done through scripts?
mspeer
Hi!
You can use Booleans only on Polygon objects, but not on individual faces.
Thanks for reply.
I don't have any experience with scripts, but shouldn't it be possible to implement boolean logic operations for sets?
How can I get all geometry assigned to a set from code?
mspeer
Hi!
You can't do for example Set1 - Set2.
What you may be looking for is this, Bool for Maya
https://vimeo.com/230275140
