Beginner needs help
Beginner needs help
Beginner needs help
Hi guys, I can't understand what I did wrong, but I have two problems with my warehouse project.
  1. One object of the warehouse (part 2 on the image) has no visible corners.     The corners are not rounded, but they appears rounded.
Rounded corners2. When I zoom out, some black optic distortion appears on the object.
Surface distortion
Please help
damaggio
Its your normals...make them hard...Normals>Harden edges   that's on top of menu 2015...2016 is in Mesh Display.
damaggio
The other problem is your camera clipping plane , increase the near clipping plane to.500 or 1.0
damaggio
it has to do with the scale you are working with......smaller scenes smaller clipping plane
OK, thank you. Will give it a try and report back.
I tried your advices and both problems went away.
Thank you very much
