automatic mapping pivot not moving with projectors(?)
RCandido7DLVE
Message 1 of 8
RCandido7DLVE
Im experimenting with automatic mapping, and it seems like the pivot point to move and scale moves differently, like its always ahead. Im not sure how to fix it.
Replies (7)
Message 2 of 8
damaggio
Message 3 of 8
RCandido7DLVE
yeah
Message 4 of 8
damaggio
Could you please accept a solution there to help the community please. Thank you.
Message 5 of 8
RCandido7DLVE
i mean no one ended up really solving it, i just fixed it myself
Message 6 of 8
damaggio
It would be nice if you could share how you've done it though, other students here in the Forums might encounter a similar problem and your solution could be quite helpful.
Message 7 of 8
RCandido7DLVE
except i dont fully remember
Message 8 of 8
damaggio
No worries then Rebecca.
When you do an automatic mapping you don't  move the manipulator, the function is already finished, it gives you a very good projection for starting your UVs, just click on Automatic Map and it will lay out the UVs for you, all you need to do next is start sewing the desired UV edges and rearrange the UV shells according to your liking or use the Uv Editor >Modify>Layout .
Once you are happy with the Layout you can save a picture of it in the right resolution and proceed with painting in photoshop or export the mesh for painting in any other app.👍
