Announcements
[2023.3] Convert Subdiv to Polygons - Uniform - Level 0 gives wrong output
ltmf1990
ltmf1990
I found a problem, it's basically ruining my workflow.
Convert Subdiv to Polygons with Uniform tessellation method at Level 0 gives an output of Level 1. The Level 0 output is not created properly.
I need to bring Subdiv object into Polygons without needlessly increasing the poly count.
Bests,
E
Christoph_Schaedl
Could you show us some example images.
https://linktr.ee/cg_oglu
ltmf1990
Edit: I found an alternative workflow in the end. See end of post.
Yes. First, I create a shape using NURBS curve, Revolve surface, and a deform lattice.
Then, I convert NURBS to Subdiv. I'm doing a low-poly game, so this is the actual result I would like, but in polygon object. If I try to convert NURBS to Polygon directly, I won't get the shape proper. It will be messed up and the topology will not be good, which is why I prefer the intermediate step passing by Subdiv conversion.
So next, I try to convert Subdiv to polygon. I tried Level 0 and it gives the same result as Level 1. I think it is because we are forced to divide at least once. I do not understand why I need to divide. It seems like it should be an easy math problem for the computer to convert without adding any polygons.
In the end, I can manually Alt Delete loop rings, but that's tedious. I was looking for a faster workflow.
If you're looking to make something similar as I, I ended up making a linear EP curve profile for my Revolve surface operation. Then, I ended up converting directly to Polygon using the Control point conversion method and I got a result that is what I need for my project finally.
_sebastian_f
use vertices as tesselation method.
but be aware that it´s usually the same topology as if you output your revolve directly as polys with controle points as tesselation method. the resulting topo is in the nature of the path you chose.
