Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
reset 4 panel view top/front/side/perp views
11 REPLIES 11
Message 1 of 12
22327 Views, 11 Replies
New to MayaLT so this may have been ask and answered but I couldn't find it.
MayaLT, when selecting the Four View Icon on the left side around the middle to get four views of top, front, Persp, and side I always end up with these getting changed, no matter how careful I am to avoid this.
My question is how do I get them back to the default settings with View 1 = Top, View 2 = Perspective, View 3 = Front, and View 4 = Side.
As you can see in the image below the defaults are no longer in play.
I would like to know the process for resetting them back to the way they default to View 1 = Top, View 2 = Perspective, View 3 = Front, and View 4 = Side.
Thanks.
11 REPLIES 11
Message 2 of 12
tony.su
You can  right click on the icon, and edit it.
Tony Su
Product Support
Message 3 of 12
Not the solution I am looking for but thanks. I am looking to reset the four views to what they say they are in my previously posted image.  Right now Views 1, 2, 3 and 4 are NOT the ones shown. View One say it is top but it is actually front, View 2 says it is TOP, View 2 says Persp but it actually is TOP, and View 4 is side.
I want to change the views back to the default settings.  I am trying to get the views to work as they do when first opening a new file. Somehow these views get switched around and do not work as expected.
Thanks.
Message 4 of 12
tony.su
Message 5 of 12
in reply to: tony.su
Thanks to all that replied. I have found the solution but it was not what I thought it would be. It is more a matter of keeping track of what window or panel your in when viewing the model.
I have found a way to obtain the results I am looking for.
Please consider this issue closed.
Message 6 of 12
What was it?
Message 7 of 12
Hallo
Can you remember what your solution was? I have the same issue and wonder if someone could help.
Thank you
Message 8 of 12
Didn't find one
Message 9 of 12
Message 10 of 12
PortalFPv
None of these work for resetting the 4 view panels.
Solution....In each view they will need to be manually set to the correct view.
In each viewport go to Panel-->Orthographic-->and select Front, Top, Side accordingly
Then in each viewport go to View-->View Along Axis-->and select X,Y,Z,-X,-Y,-Z accordingly
Message 11 of 12
hanna_vass
in reply to: PortalFPv
Thank you! This solved the problem for me!
Message 12 of 12
kailashtakhar7878
Hi
