non-planar faces Bug
Message 1 of 17
if i create a cube and scale one face. then do a clean up select i get non-planar faces. can anyone help me with this.
Replies (16)
Message 2 of 17
Is this normal should i ignore it. Can someone help me please. It would be greatly appreciated.
Message 3 of 17
saihtam
That does not happen here, Maya 2015 (not LT). You do nothing else to the cube? Can you post a picture of what's happening?
- Mathias
Message 4 of 17
here are some screenshots of what i mean. i scale a face then do a clean up select and it selects some non-planer faces.
Message 5 of 17
can any one help im wasting money. i cant work till i fix this issue.
Message 6 of 17
i just tryed make a sphere and i did a clean up and i get non planers agian. can anyone please help me.
Message 7 of 17
Carlos_Carpintero
Hi blood_wolf_live,
I am not getting this issue either.
In the image you attached with the Cleanup options, you have 3 other options selected along with Non-planar faces. Why are you under the impression it's non-planar faces that are being selected?
That being said, it's a puzzle to me why anything at all is being selected since you are using a default cube.
Have you tried to reset your preferences?  Also, in the Cleanup Options, in the Fix by Tesselation section, unclick everything except Non-planar faces to verify that it is indeed non-planar faces that are being selected.  Delete the construction history and freeze the transformations on the cube just to eliminate other variables.
Carlos
Message 8 of 17
Thank you for replaying. but i have tried all what you have said just know. but im still getting non planer. in clean up options i only checked no planer and i delete the construction history and freeze the transformations. im still getting non-planer faces. i have reset all preferences to default but nothing. i have even uninstalled and reinstalled but nothing is seems to fix it. hope you can help.
Message 9 of 17
Carlos_Carpintero
Ok, try the following please.
Create your cube and then enter the following command in the command line:  setPolygonDisplaySettings("nonPlanar");   (you can also accomplish the same thing by going to Display>Polygons>Non-planar Faces)
This command toggles the display of non-planar faces to ON.  I would like to know at what point the faces become non-planar.  My feeling is that this is a display issue, but I can't be sure at the moment.
-Carlos
Message 10 of 17
ok i did as you said but nothing is highlighted. but i know the highlighting works because if i move one of the vert it highlights.
Message 11 of 17
Carlos_Carpintero
Moving one vertice will produce non-planar faces, this is normal.  By definition, a non-planar face is a face that has more than three vertices, and one or more of those vertices does not lie in the same plane. (see https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Maya/fil...
If you select a face on your cube and rotate it, this will also produce non-planar faces.  Scaling a face should not produce any though as far as I know.
Can you tell me the version and build of Maya Lt you are using? Do the following commands to find out:
about -c;
about -iv;
Also, please send me your scene with the cube.  If you can't attach it to this forum, you can send it directly to me at carlos.carpintero@autodesk.com.
Carlos
Message 12 of 17
ok here you go. hope you can help. could not attach it so i but it in a zip file.
201511271533-979388-1
Autodesk Maya LT 2016 Extension 2 SP4
Message 13 of 17
Carlos_Carpintero
I've opened your file and I don't see any non-planar faces. More and more I am thinking there is something going on with your particular system.
I noticed that there is something different in the Maya looks and feels when I open your file.  The way the cube is drawn, along the edges we see black triangles.  If I do Display>Polygons>Face Triangles, we see the dotted lines of the triangles from the rear faces.
The grid is different from the default grid, and if I go to Display>Grid Option box and press Apply, the grid shrinks down to it's original correct size.
Do you change the default Maya setup? Or, do you run any Script Nodes when you open a new scene?
cc
Message 14 of 17
i did change the grid size when i was working on a large abject. but that's all that i changed. im not using any Script Nodes.
Message 15 of 17
Carlos_Carpintero
I hate to admit it, but I am stumped.
I've looked through our database of bugs and haven't found anything concerning non-planar faces appearing after scaling a face.
Some other ideas to try:
1. Reset everything to Maya's default, so grid size, or world size, camera settings, etc.
2. Update video drivers
The silver lining with all this I think is that non-planar faces are not necessarily bad. Non-planar faces can be smoothed, rendered and all the modelling tools should still work fine.
Non-manifold geometry is the thing you need to avoid since Maya's modelling tools will give unpredictable results.  You can learn more here: https://knowledge.autodesk.com/support/maya-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/MayaL...
If I learn of anything new I'll update this thread.  Or if you find the reason it's happening, please let us know.
Carlos
Message 16 of 17
Thank you for all your help it seem ones i restored the grid size to its default settings it seems to have fixed the non-planer faces. know i can make a cube and scale a face i do a clean up and nothing is found. thank you for your time and helping me with this issue.
Message 17 of 17
Carlos_Carpintero
Excellent, I am really happy my suggestion helped you.
If you have time, can you please give the exact steps on how you set up your grid?  There may be a bug there that hasn't been seen before.
If you don't have time, that is ok, I will try and repro your setup.
All the best,
Carlos
