I have this circular UV that I think would be better laid out if it was a strip in the UV page. I cut a seam in it, how can I get it to form a straight line similar to the above UVs? Is this possible?
Hi Krato,
It's definitely possible. There are a couple of ways to do this:
1.) If you're on the newest version of Maya LT (2017 Update 3), it's as easy as selecting those faces and then going to Unfold > Unfold in the UV Toolkit.
2.) If you're on an older version, then I'd suggest selecting those faces and applying a Cylindrical UV Mapping to them (http://help.autodesk.com/view/MAYALT/2017/ENU/?guid=GUID-06864409-CC4C-4C40-B04D-6D5060A9FEF0). That will project them straight, but flat. To unflatten, select the UVs on just one side and translate them up.
@Anonymous nailed it both of these steps can work well but I recommend cylindrical mapping! It tends to be cleaner 🙂
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
