Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
Maya LT 2019 BUG: Changing one object's pivot changes all pivots on others.
8 REPLIES 8
Message 1 of 9
baez_isaac
1338 Views, 8 Replies
Maya LT 2019 has a bug when changing the pivot on one object changes the pivot on others in a scene. Even after resting setting and starting a new scene this still occurs.
Tags (1)
8 REPLIES 8
Message 2 of 9
jordan.giboney
in reply to: baez_isaac
Hi @baez_isaac
Thanks for reporting this! It definitely seems like there is a discrepancy between Maya LT 2018 and 2019 in this behavior. When you were editing your pivot point in the video, were you holding down the d key to do so? Or a different method? Just want to make sure I am following the same process.
For future reference (and to spread the knowledge on the forum), we also have the Autodesk Report a Bug tool for Maya 🙂 You can submit info like this directly to our QA team for testing.
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 9
baez_isaac
in reply to: jordan.giboney
Hello Jordan,
Yes in the video I am using the D key to move the pivot point around.  Also thanks for the link on where I can post any bug I find.
Message 4 of 9
jordan.giboney
Awesome! 🙂 I logged it internally as well, but the more reports the better!
Thanks again for posting.
Jordan Giboney
Message 5 of 9
This glitch is driving me crazy! I'm SO GLAD that someone else brought it up because I would have thought it might just be my computer or license. I'll submit a ticket myself. Thanks Jordan for your attention to it as well.
Ihab
Message 6 of 9
Did you guys found a solution for this bug?
I'm having the same problem in here.
Message 7 of 9
I haven't found a solution for this in Maya LT 2019 for this pivot issue. I actually moved on to the Indie Maya license because of this bug. I haven't used Maya LT 2020 so they might of fixed it.
Message 8 of 9
I see.
I'm actually using Maya 2018, I have already reseted everything but the problem persists.
Anyway, thank you very much for the feedback.
Message 9 of 9
vladissoula
Solution: Open Move Tool Settings window and click reset tool, repeat for the scale and rotate tools
