Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
Import FBX problems
3 ANTWORTEN 3
Nachricht 1 von 4
2427 Aufrufe, 3 Antworten
Import FBX problems
I am unable to import some static meshes exported from Unreal.
 Error: FBXImport error: take not found.
I can open them fine with FBXReview or Blender.
Since they are static meshes, there is no animation, so not sure why the error is Take Not Found.
:enttäuschtes_Gesicht:
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
solved by manually editing options and uncheclking animation.
Seems like if the file has no animation take, then the program should not try to load an animation?
Nachricht 3 von 4
RichardSuchy
I know this is ancient but--
Unloading and reloading the FBX plugin resolves this for a while. Sometime a failed import breaks the plugin and then you get that error. It happens a lot in Maya 2022.
Not sure but it may be related to the source of the FBX. In my case it might have been either or both Blender and/or Cinema 4D that makes it happen, or just importing into an existing scene with similar names. Seems almost random.
Nachricht 4 von 4
i_karadzhinova
als Antwort auf: RichardSuchy
THANK YOU OH MY GOD
