Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
2018 + macOS: "OpenSubdiv Catmull-Clark Adaptive" smooth mesh is transparent
2 REPLIES 2
1445 Views, 2 Replies
I ran into this issue recently: when a smooth mesh is set to use "OpenSubdiv Catmull-Clark Adaptive" instead of the "OpenSubdiv Catmull-Clark", the smooth mesh is not displayed, not even the wireframe.
See the link for details, I am really not sure this is a bug or by design.
My OS is macOS 10.13.2 (on a Macbook Pro 2015), and I am using Maya LT 2018. Let me know if you are able to reproduce this issue.
2 REPLIES 2
sean.heasley
Hi @Anonymous
I believe you are right and that it is a bug. The issue occurs in 2018 and 2017 LT however won't occur in standard Maya 2017 or 2018.
Also, if you change from Adaptive to the default Catmull-Clark you should be able to continue working normally!
That said I went ahead and logged this with our dev team so they can work on a fix!
Please let me know if there's anything else you need help with!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
MelissaClark347
Same problem. It helped a lot.
