SceneTimeWarp - remove some small bugs
When adding keys while scene time warp is active, they become completely wrong.
At least a warning must appear, to disable it first.
When SceneTimeWarp is enabled, the visible key ticks on the timeline should either move, where they really are.
Maybe they get a different color (violett/purple for example), this would be ideal.
Or at least something should show, that what you look at is no more valid (again a color in timeline maybe)
Bug (or I did not understand the behaviour):
When you have time1 and SceneTimeWarp window both open, you will see that something is wrong connected.
If you toggle in time1 the SceneTimeWarp it does not toggle the same in the panel.
When toggle it in the panel it toggles it at time1.
If someone uses the button in time1, it gets completely messed up with consequential errors...
see attached picture
2 Comments
A_lunga
@BenediZ Thank you. We've logged this into system, and it will be addressed
891198
5 years and the error is still there
