Show only
Search instead for
We're looking in to this and have something in our beta already. Would love to get more detail on how you want to see the workflow. We have some ideas in mind, but the more detail you give here the better.
Thanks for replying. That's great news! I think it should be kept fairly simple. For example, select a vertex/face/edge and click a rivet button t create a rivet on that specific point.
It would be nice if it had a toggle for following the normals. But if you dont want rotation, it should be able to stay fixed.
In theory it could be a locator but like i have said in a previous post, locators have problems when you freeze transformation and then bake its pivot in order to get its SRT values in the channel box. So thats a bit tricky for rigging. But whether it's a group, a locator or something new, i dont mind.
I think you could make them function similar to follicles but without all the extra bloat the follicle nodes have for hair systems. The output should be translate/rotate/scale(?) values that you can then plug into a transform. PLEASE no shape/transform node inserted into the hierarchy (it does not need to be a DAG node)....
For nurbs, inputs would be as simple as a surface, and uv parameters, maybe an additional attribute for whether u or v should be treated as the up axis (the normal would be the aim)
For polys a good idea for inputs is a little harder... maybe uv parameters (but that requires uvs)? Maybe a poly face with some sort of implicit uv parameters within that face for position? Maybe along an edge? Maybe a vertex that would give very easy position values. Maybe several vertices, it would need to keep relative distance between those verts along the surface... If you attach it anywhere but on a vertex, you need some way to specify it's position (where inside the face? where along the curve? where in relation to multiple verts?). You would also need some way of getting orientation (uvs, maybe?) I think follicles work off the uv parameters, so maybe that's fine (although, getting a specific vertex's position data could be nice too)?
Essentially, a node that does what the simple 4x4 matrix/decompose matrix node network toward the bottom of this blog post does:
As for workflow, I script most things, so I would just create it manually, hook up the inputs, and output it to a transform I also created; however, for interactive use, maybe you could provide a surface/poly and a node (transform) you want to rivet (the transform should be positioned where you want it to "stick"), then you run the command/click the ui rivet button, and it determines the appropriate closest uv values and stuff for you... You could have an option for creating a buffer transform or not - say the user created geometry shaped like a button and wants to rivet it to a shirt - directly driving the button's transform would move/rotate it, so inserting a buffer node and then auto-parenting it could be a nice feature (although unnecessary if you have and empty transform)
My free tool allows you to create one or many rivets at once, reposition them after creation and move them freely while still retaining their parent influence.
Thanks a lot for the help, Forrest. your script is amazing, but unfortunatelly its working with the same behavior of pointOnPoly constraint.. it interprets the normals differently from the rivet command (maya 2020).
I am attaching an image to show you what I mean... one point was created with rivet command, another one with the script you sent me.. I aligned boxes to each of them before translating the vertex..
So when I translate the vertex, the boxes unmatches... 😕
the command is very useful.. but would you know some faster way to apply rivets? maybe via openmaya api? Im asking that because I would need to apply the rivets in a 20k times loop.
The rivet command works on multiple components at a time, so if you have selected 20k components, the command will create 20k rivets for you.
The rivet command is nothing more than a wrapper around the uvPin node creation that uses a simplified set of options. You'll notice that after it is created you have a uvPin node.
The uvPin node uses a new python framework for creation, so all the python scripts that create it are available to you for inspection. You'll notice it is wrapped in an "internal" namespace though. This is because it is not yet a public API as we clean some things up. So expect the following code to change on you.
To inspect it you can do the following. Turn on echo all commands in your script editor. Then run the rivet command. You'll see it will spit out something like this.
