Pipe / Wire creation toolkit
(Copied from original User Voice forum)
Modelers want a quick and easy way to generate 3D pipes or wires in Maya.
"Please have a proper way to create pipe or tube that don't flip!  With all the method available in maya, extrude a nurbs curve, paint effect convert to poly or whatever, none will be able to give a pipe or tube that won't flip once the direction of the curve break and the normal of the curve must change..this is annoying this problem doesn't exist in max, XSI, modo or any other apps I know! it should be addressed! thanks"
"Complex tubing and pipe geometry can be a pain to implement/model quickly in Maya.  Could you Please look into adding a check box or something to that effect similar to 3dsmax, where an artist can position curves and then hit [make geometry] and a function to choose between geometry type (Poly/Nurbs/subD) and have some tessellation options."
Some links:
https://gumroad.com/l/primGen
https://gumroad.com/l/QPipe1a
12 Comments
fabrizio.arzani
@trevor.adams also zpipemaker...
http://zukodesign.com/zpipemaker.html
simple but it was quite good, foremost the version that allowed you to use your own modules.
trevor.adams
Thanks @fabrizio.arzani!
trevor.adams
g2m.agent
philstrahl
It disappeared from the Autodesk App Store! 😞
g2m.agent
here is Wire v0.3 for Maya 2018-2019 win
https://we.tl/t-ds5rsl5x8v
the author promised the 2020 version, but I think he has encountered some problems
philstrahl
Thank you so much! ❤️
trevor.adams
Status changed to: Accepted
Nastya19900709
Community Visitor
@g2m.agent sorry, do you have a plugin Wire by Piotr Makal? I can't find it anywhere. I will be very grateful if you share it!
g2m.agent
Wire 0.3 for Maya 2018-2019 by Piotr Makal.
https://we.tl/t-UmLLlZf0Ol
Nastya19900709
Community Visitor
@g2m.agent Thank you so much!!
trevor.adams
Solved.
Check out our new Sweep Mesh feature in Maya 2022: https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=GUID-C420C944-876A-4ED8-BA70-084533171029
Check out what else is new in Maya 2022 by watching this highlight video (https://www.youtube.com/watch?v=CyPkTeJ9vJ8) or by reviewing the What's New section in the latest docs (https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=GUID-90A9A2C7-C8E3-4B4E-8C94-63553069F51E). Thanks for voting (and waiting) on this one.
