I would love to disable Mayas insistance that 'unit conversion' nodes should be inserted everywhere. I often use 'Multiply Divide' nodes between two connections of a similar type and I end up with two unit conversion nodes per axis, which are just converting one way then converting back again pointlessly (and using resources presumably). I can set them all to '1' in which case they do nothing and the behavior is the same. They also aggravate node editor issues of muddled appearance and general annoying behavior.
I would suggest that unit conversion nodes aren't applicable to 'multiply divide' nodes, or most other nodes for that matter.
