Filters in the File Dialog box are cleared when a file is selected
Starting in 2018, if the user is filtering in the File Dialog (using standard characters and/or wildcards), as soon as the user clicks a file in the filtered file listing, the filter is CLEARED.
This did not happen in 2017 and prior. The filter used to stay active no mater the file selection. It would only change if the filter itself was changed. With this behavior, the user could still multi-select, rename, etc files that were filtered to appear.
Please return this to Pre-2018 behavior.
8 Comments
feyi.agbaje
Status changed to: Archived
Hi @jmalaska, thanks for bringing this issue to our attention. It has been logged as MAYA-93382: Filters in the File Dialog box are cleared when a file is selected.
ashaiad6194
can you please give us more details
are you working with 2018.3 ? or 2018 gold
  1. file open
  2. type in *.ma
  3. then I select a folder
  4. my *.ma is still there
jmalaska
I just verified the issue persists in 2018.3.
To verify:
  1. I have a folder full of .ma and .mb files.
  2. I enter the text "*.ma" to filter only the .ma files.
  3. When I hit Enter, only the .ma files show up. I select one of the .ma files.
  4. Upon selecting, the filter disappears and is replaced with the name of the file I selected, and the filter is no longer applied.
ashaiad6194
Please see my attached file
the behavior is the same in 2016 and up
jmalaska
Here's what I'm seeing in a clean install of 2018.3. The filter is cleared when I select a file, but not when I select a folder. Prior to 2018 it didn't clear upon selecting a file.
ashaiad6194
Thanks for the video.. this is expected
can you please show me in 2017 how it's not doing the same behavior
jmalaska
No problem. Though I am not sure I follow why the file list behavior in 2018 is expected?
From the 2016 video you posted: the filter is set, a file is selected, but the filter doesn't clear out -- the single MB file is only visible and not the full directory.
In the video I posed from 2018: the filter is set, a file is selected, and the filter is cleared out exposing the rest of the files in the directory.
Just want to make sure we are on the right track. Can you confirm these behaviors are different between 2016 and 2018?
ashaiad6194
OK OK ..I got your point now
sorry took me a bit to understand
